Brake light comes on after first application of brakes
Old Apr 6, 2019 | 11:46 AM
bighank's Avatar
Question Brake light comes on after first application of brakes
2002 Silverado 1500 2WD long bed with AT.
Just raised 6 inches with Rough Country lift kit. Left front brake was binding. Removed caliper and caliper bracket. Caliper guide pins would bind after inserting 3/4 of the way in. Found suspension bushing jamming at small end of guide pin bolt. Replaced OEM guide pin bolts with torx or star key with new ones which have hex bolt heads. Pins otherwise look identical to OEM torx head pins. Put rubber suspension bushings on pins and lubed with caliper grease. Bushings bind on pins and move past smaller part of pin and bind in caliper bracket. Worked on this for over an hour with no success. Removed rubber guide pin suspension bushings and inserted pins in caliper bracket. No more binding. Assembled calipers and test drove truck. Now the brakes seem normal, No pulling to one side or binding but the brake light comes on after first application of the brakes.
Where is the pressure operated switch which will turn on the light if there is an imbalance in the brake pressure?
Is it the connector on the master cylinder or at the ABS control module in the center passenger side if the frame rail?
I know the brake light will also come on with parking brake on. Checking that even thought i have removed almost all pressure on PB cables.
I do not see any fluid coming out from any brake line and the pedal is firm and not spongy.
Old Apr 7, 2019 | 10:25 AM
to determine if the problem is the ebrake, brake fluid level switch or ebcm...
-remove the connector from the brake fluid level sensor at the master cylinder reservoir.... test drive...is the light off?....no... test ebrake
-remove the connector at the ebrake lever...test drive...is the light off? no...check for codes in the ebcm with a full function scan tool...code reader will not read chassis codes.
