Brake Valve Identification?
Old Jul 4, 2011 | 6:44 PM
sah62's Avatar
Default Brake Valve Identification?
I recently removed a pressure differential valve/distribution block (see attached image) from the left front frame rail of a 1970 Impala. I'd like to understand if the same (or a similar) valve was used on any other Chevy or GM vehicles. The InlineTube web site (Product Info) lists several applications, but the valve body in their picture looks a little different than the one attached here.
I'm asking because my company (see my sig) is in the business of producing rebuild kits for a small number of brake valves and I'm looking to expand into GM applications. This valve can be disassembled and I can provide the parts to rebuild it, but I need to confirm two things first:
  • Original applications, and
  • Interest - are people looking to rebuild these valves?
Are the applications listed on the InlineTube page correct? Would you be interested in a rebuild kit if cost approximately $20 - $25 or less? Do you know of other brake valves that might be worth rebuilding if a kit were available?
Old Jul 4, 2011 | 7:59 PM
sah62's Avatar
I just finished posting an article on my site that describes how the valve can be disassembled:
1970 GM Pressure Differential Valve Autopsy | Muscle Car Research LLC
A rebuild would require clean up, replacement of the seals and springs, and reassembly.
454BBC
Apr 30, 2013 5:48 PM
TahoeMatt
Feb 28, 2013 8:13 PM
83_Caprice_Classic
Sep 21, 2010 2:12 PM
tbear
Astro
Sep 22, 2008 4:43 PM
