Bypass the ignition system
Old Dec 14, 2021 | 10:51 AM
Jrdnoland's Avatar
Default Bypass the ignition system
I just finished rebuilding an older column for my 1974 chevy malibu. Got it all in and wired but it won't start. I have to move the car very soon, so I was going to try and bypass the ignition switch.
There are two switches on the steering column, I think the ignition switch is the one closest to the steering wheel where the steering column linkage fits into. I pull the wires back off the column and was trying to use a momentary switch to get the car running. Nothing happened, I think I may be using the wrong wires? Does anyone know how to get this car to start and drive using the steering column wires.
I just got the car from my brother who died and have not yet ordered a service manual. The column was broke so I took it out and did the best I could rebuilding it. Also having a slight issue with getting the lower shaft to fit the part that goes from the gear box up. Any suggestions on this issue?
Appreciate any help I can get.
Old Dec 14, 2021 | 11:16 AM
Welcome from Florida. Make sure the neutral safety switch is working and wired properly. If the harness is in bad shape you might have to get another one from a vintage car junk yard. There are several of them if you do a search on Google. You might be able to make a harness yourself if you can get hold of a schematic.
Old Dec 14, 2021 | 12:50 PM
Jrdnoland's Avatar
Thanks, oldchevy. The neutral safety switch/ignition switch has been taken off. Was thinking that I could use a momentary switch to get the car to start and run. Not sure what wires from it to jump? Is there more to it than that?
woodie1987
Nova & Chevy II
Apr 18, 2021 10:17 AM
Pardeecrooks
Nov 28, 2016 6:36 PM
Jeremy Ray
1988 - 1998 (GMT400)
May 3, 2016 4:12 AM
Høvding Jarle Haugdal
Apr 5, 2012 4:05 PM
cb1
Oct 24, 2010 12:13 PM
