Cams and lifters
Old Feb 26, 2016 | 7:36 AM
Smilie's Avatar
Default Cams and lifters
I've been wondering about this for some time. Is there any reason why you can't put roller lifters on a flat tappet cam?
Old Feb 26, 2016 | 11:27 AM
old dog's Avatar
the two cams are made of dissimulator metals ,and accelerated wear would happen .you only want to use new product.s only on flat tappet ,you can get away with replacing only lifters on a roller cam .
roller cams are made out of billet steel generally .
flat tappet and hydraulic cams are typically are made out of nodular cast iron .
Old Feb 27, 2016 | 10:36 AM
SWHouston's Avatar
Also, rollers are quite a bit heavier, one should consider springs for the additional weight and higher revs. Customarily, rollers are used to reduce wear on a very high lift Cam.
