Camshaft specification data sheet help request
Old Apr 21, 2024 | 5:14 PM
EVTECH88's Avatar
Default Camshaft specification data sheet help request
Hello Folks from the UK
I have a tech question please I hope you folk might be able to help with.
I have a Camshaft as labelled up in the diagram I would like to obtain the data sheet for for cam timing it up in a fresh engine build.
I will be measuring it to obtain some profile specifics but the stamps on the cam are
SBC 1126 (2) MKU2
The camshaft is taken from a drag strip use overbore sbc running low 9s on the quarter mile with a modest NOS bump.
I can find a summit racing 1126 cam easy enough on the web but the other numbers confuse and dont result in a good match. The summit site explains power band between 3200 to 6500 rpm but the car has a shift light set at 7k and even 7k seems conservative as it pulls very stong through to that and dyno plots support this so its not just revs for revs sake. This makes me query if this is a version of the 1126 with the suffiix (2).
I'm not an expert on these engines so thought I would query it here if anyone can better advise.
thanks in advance to all replies.
snillboy
Jun 16, 2022 11:11 PM
Todd_tn
Jan 28, 2021 8:17 AM
SilveradoChuck
Mar 13, 2017 7:14 PM
jonathan_l_b
Dec 25, 2013 6:16 AM
