Can a 95 4L80E go into a 91 silverado?
Old Dec 19, 2018 | 3:23 AM
roamer12's Avatar
Default Can a 95 4L80E go into a 91 silverado?
I have 91 Silverado 2500 4x4 and have a 95 4L80E.
Can I swap the digital range selector into the manual lever position sensor?
I had previously installed a 94 4L80E into the 91 and rewired the harness plug,
but the 94 is a manual lever position sensor.
Old Jan 9, 2019 | 1:27 AM
roamer12's Avatar
Default Update remedy 😁
The answer is yes.
I pulled the pan on both,pulled the manual shift rod out of the 91 4l80e and pulled the 95 shift rod with the neutral safety switch out.
Put the manual shift rod in the 95 4l80e.
The 95 4l80e is in the 91 Silverado,and it shifts great no issues.
