catalatic converters
Old Sep 23, 2014 | 2:18 PM
happyman83's Avatar
Default catalatic converters
I have duel cats on my 96 GMC I want to take them off how can I do that with the 02 sensors being before and after the cats
Old Sep 23, 2014 | 8:31 PM
mikeatpriestlake's Avatar
Default Cats
why remove the cats? They can be cleaned , also, you could end up with chronic check engine light. are you sure its worth it?
Old Sep 24, 2014 | 9:34 AM
happyman83's Avatar
Well if I can clean them even better how do I do that
Old Sep 26, 2014 | 5:10 PM
You have 2 choices, first, you could try lacquer thinner in the fuel tank. this is an easy try. the ratio is 1 gallon thinner to 9 gallons of gas. If you have questions about doing this, go watch the video about it at scottykilmer.com. also, you could remove them and soak them for several hours or overnight in a household detergent and water bath. If you do opt for the thinner in the gas deal, you will have to drive the car for a couple of hours at highway speeds for it to do any good. I would definately watch that vid. good luck.
kb4422
Jan 21, 2008 12:40 PM
sellersoasis
Jan 3, 2008 4:30 PM
sellersoasis
Aug 4, 2007 8:41 PM
BlackBeauty
Jun 22, 2007 1:05 PM
ohiotrader
Jan 31, 2007 1:18 AM
