Change rocker arms
Old Oct 14, 2014 | 9:53 AM
2butterbeans's Avatar
Question Change rocker arms
Guys I am new to the site and hope you can help me. I have a 86 k10 truck with a 350 with a small cam. I would like to change the rocker arms. Now it has the stock 1.5 on the truck I would like to put the roller tips 1.6. Can I do this without any problems ? Someone told me that the push rods would rub the head. But I don't know. I'm sure some of you guys have tried this. What happened? Did it work? Thank You for any help.
Old Oct 15, 2014 | 8:12 PM
Exgie's Avatar
1.6 ratio rockers are special application rockers. Some people think it is a way to cheat and get a little more lift out of there baby camshaft.
None of your push rod, rocker, valve tip geometry will be correct if you do this. If you need a bigger cam put in a bigger cam. 1.6 rockers are not the way to get more lift. You will create more troubles than the nominal lift you will obtain.
Old Oct 16, 2014 | 7:24 PM
Default Thanks
Yes you are right I was trying to get a little more out of my cam. But now I will rethink this.,
Old Oct 17, 2014 | 9:52 AM
Exgie's Avatar
Yeah if you want more cam install a bigger cam. You could also degree the cam in and get small gains by advancing or retarding the cam.
praza
Jul 1, 2013 2:57 PM
eibarra914
Aug 28, 2012 1:36 PM
Balthazar00
Feb 16, 2011 11:32 PM
cams 98 silverado
Nov 2, 2008 11:19 PM
