Changing from 2wd to 4x4 without hitting button
Old Jul 12, 2013 | 5:43 PM
sail2383's Avatar
Default Changing from 2wd to 4x4 without hitting button
I have a 2004 suburban z71 it will shift from two to four wheel drive without me hitting the button while driving down rd. I've reserched it and it is either the push butto n in side or the actuator what do you think I should by first?
Old Jul 17, 2013 | 12:48 PM
RB Auto Service's Avatar
A multimeter with a high capture rate or a cheap oscilloscope, a service manual, and maybe a scan tool that can read live data from all modules. If parts swapping is your technique of choice choose the cheapest part or the one that will be easiest to keep clean so you can return it. In this case probably the switch.
aboyaser
Nov 20, 2012 9:04 AM
admmck
Oct 10, 2009 11:17 PM
proud_sierra_driver
May 21, 2009 1:00 AM
4wheelR
Feb 12, 2008 3:20 PM
