Chevy C6500 electrical issue
Old Aug 26, 2017 | 1:37 PM
Jonathan Hoag's Avatar
Default Chevy C6500 electrical issue
I have a 1986 Chevy C6500 firetruck with a 427 tall deck. After getting up to temperature The truck will randomly turn off and all of the gauges will drop until you switch the ignition to the off position and then back on, the truck will then backfire and the engine restarts. I have replaced the ignition switch, distributor module, coil, cap and rotor but that has not fixed the problem. The truck is also wired with a battery cutoff switch.
any ideas on this would be greatly appreciated.
Old Aug 26, 2017 | 4:59 PM
kevinkpk's Avatar
Have you replaced the ignition switch?
Old Aug 26, 2017 | 5:05 PM
I did replaced the ignition switch but it did not fix the issue.
Old Aug 26, 2017 | 5:59 PM
kevinkpk's Avatar
Battery cutoff switch? Ok, can you wire around that?
