Code PO449 2005 GMC 1500 Solenoid valve
Old Oct 15, 2010 | 6:03 PM
besse2020's Avatar
Default Code PO449 2005 GMC 1500 Solenoid valve
I had my check Engine light come on and I checked out with a AutoXray computer. It read a code of PO449 and I looked on the computer and fixed it myself. I wanted to post this to help anyone else who deals with this problem.
I first replaced the purge valve that is located on the front of the intake manifold under the hood. I was still getting the code after I reset it and had to look further and found that I have another valve located under the bed of the truck, located on the inner rear of the fuel tank attached on the outside of the tank. It is a black canister with a valve attached to it with a hose attached to it. I called the dealer and they want $288.00 to replace it with a kit that has a longer hose to move it in a safer area to avoid dust in the canister. I did try to just clean the canister and I made sure the hose was not clogged but still had the code problem. I did more research online and was able to just buy the vapor canister purge solenoid valve from am-autoparts.com for $30.50 with free shipping. All I did is just disconnect the wire connector and the quick release hose that is attached to another black plastic box assy that is located above the fuel tank. I had to install a new 4" rubber hose to attach to my new part and I reset code and it fixed the problem. There is a diagram of the part and fuel tank system I found on-line and the web-site is www.gmpartsgiant.com/components/2007-gmc-sierra-classic. Just go to the Fuel,Exhaust,Carburetion,Emisssion. You do not need the service kit that they tell you you need and that part# is 19152349 for $153.80. Just get the part from am-autoparts web-site and that part#214-2149 and this will solve your problem. If you have any questions, please just E-mail me @ www.besse2020@yahoo.com
Old Jan 5, 2016 | 10:27 PM
Heidi Braunlinger's Avatar
Where is canister and valve on 06 chevy silverado 1500 8ft bed v6
Have p0449 code.
Is it engine or under by gas tank or somewhere else
Thanks
GunnyV
Dec 30, 2024 4:03 PM
daryl
Oct 14, 2021 10:09 PM
GHOST169
Apr 24, 2017 2:12 AM
Delta-Dawn
Jan 5, 2016 10:24 PM
JRT600
19
Jun 4, 2009 11:44 AM
