Cold Air Intake/MAF sensor
Old Dec 26, 2014 | 8:33 AM
dmillerj's Avatar
Default Cold Air Intake/MAF sensor
Not sure if the answer to this question is more about opinions than fax's. I have a 2012 Tahoe 5.3 and Santa brought me a K&N Blackhawk intake that has a dry washable filter instead of an oiled one. I have read that unless you replace the stock MAF with a more performance sensor you will not realize the max benefit from this intake. I called K&N and was told that this mod is not required to max out the benefit of the intake.....but replacing the factory sensor with one that provides more air seems logical. I also read that installing a TB spacer with this intake would show an improvement in gas mileage. Does anyone have any experience with this set up?
Old Dec 26, 2014 | 10:01 AM
Fishnchipy's Avatar
You are correct, its about options. The system will work fine as it is. You could install a TB spacer ($100) and you may notice a slight difference. Depending on you state of residency be sure it meet emissions standards or you could fail the smog test. As for the MAF I went cheap and removed the screen from my stock sensor and polished the feed ramp. Been years and still works fine but could spend another $100+ and buy an aftermarket MAF. Again, your choice!
dmillerj
Dec 29, 2014 9:30 PM
dmillerj
Dec 22, 2014 8:37 PM
Mille Racer 69
17
Nov 7, 2010 4:19 PM
93bar91cor
Apr 18, 2007 1:59 AM
