Comparing Tires Calculator
Old Jan 30, 2010 | 3:09 PM
MWG2's Avatar
Default Comparing Tires Calculator
Here is a great calculator that will tell you the difference between your current tire and a new tire (size). It automatically calculates the difference in Sidewall Height, Section Width, Overall Diameter, Circumference and Revs per mile. It also tells you the difference in speed, for example, if your current tire goes 65 MPH, with the new tire your actual speed is 68.56 MPH. (See sample screen shot below.)
http://www.discounttire.com/dtcs/infoTireMath.dos
Old Dec 9, 2010 | 8:41 PM
Georooney's Avatar
Originally Posted by aja72
Shocking, i want to try this calculator. Tell me how can i use this.
Click the link.
Old Jan 13, 2011 | 2:39 PM
mccarthy's Avatar
Hey i am hearing this for the first time. amazing calculator it looks cool man there is no necessary. for us to maintain all these stats. because calculator well help us.
Old Mar 8, 2012 | 9:36 AM
SWHouston's Avatar
Fellas, this calculator has been available for quite a while, and linked on this Forum numerous times. However...
I'd suggest that you use your OEM size in the first three cells, it'll give you more accurate info, specially since many are not running the exact OEM.
Other than that, just follow the directions.
Old Mar 21, 2012 | 12:27 PM
Johnnyson's Avatar
shocking and its very interesting and i want to use it.
Old Oct 8, 2012 | 9:49 AM
Malibu Mike's Avatar
Cool link!
Old Nov 23, 2012 | 6:50 AM
SWHouston's Avatar
Originally Posted by dianneazuma54
How much leeway is there in tire sizes?
Ha, the sky's the limit, as long as you are aware of changes different tires make. Most times people do this for cosmetic reasons, and others for functional. In either case, there are trade-offs in the ride, handling, breaking, center of gravity and load carrying ability.
Now, if you're just talking about a slightly larger tire on your existing rims...
The rule of thumb is...
That you don't go with a Tire that's over 1" wider than your Rim Width.
(is that what you meant ?)
Old Dec 3, 2012 | 12:51 AM
alliknight's Avatar
Default garage door repair springfield
Nice!I like your post and also the color of the car..Nothing to worry about problem it looks like very compatible..
Thank you for sharing here
Old Jan 4, 2013 | 10:50 PM
Dobrovit's Avatar
woow thats amazing link to look up at.. i liked it a lot and would recommend others to use it....
Old Jan 15, 2013 | 2:02 PM
SWHouston's Avatar
Default Tire Size Difference Calculator
The only Calculator that I can find on this Site, is one for Offset at...
There is however a Difference Calculator which gives you Speedometer error differences at...
Tire Dimensions Made Simple - Discount Tire
If I have somehow missed this feature on this Site, please post the location.
