Constant Battery Draw?
Old Nov 21, 2007 | 5:39 PM
catman23's Avatar
Default Constant Battery Draw?
Anyone know how to locate a constant battery draw? I don't have the problem now, would just like to know for future reference. Thanks.
Old Nov 21, 2007 | 9:57 PM
John86's Avatar
Default RE: Constant Battery Draw?
yea u do a amp. draw with a voltmeter. hook it inline with the positive battery cable by unhooking it and putting one end on the battery and the other on the terminal. wait like 10mins for everything to go into sleep mode again and read how many milliamps u r drawing.
Old Nov 22, 2007 | 8:35 PM
Scoper50's Avatar
Also, I would like to add.... If you find a key off draw using the method described above you can start pulling fuses one at a time until the draw on the meter dissappears. Doing this, you can narrow down the problem to a particular circuit.
Old Nov 23, 2007 | 10:00 PM
golfer's Avatar
This is referred to as " parasitic drain " , all modern vehicles will normally have a small amount of parasitic drain for the various electronic control modules and constant memory for things like stereos, etc.
The test for this :
With a Multimeter set to DC amps , without the key in the ignition, doors closed and everything OFF
1 - disconnect the Negative battery cable
2 - attach one lead from the meter to this negative cable
3 - attach the other meter lead to the negative battery point
wait a few minutes for the reading to settle ( this is for everything to re-initialize ) and observe the reading, which should be somewhere in the ball park of .010 (milliamp) to .020 (milliamp). [ 1 amp = 1000 milliamp and 1/2 amp = .500 amp or 500 milliamp ]
This will depend on what accessories your vehicle has.
If you find a high reading , for example .500 amps ( 500 milliamp ), you can do one of two things to locate which circuit is responsible for the high draw.
- leave everything connected as mentioned above
- remove one fuse at a time and see if the reading drops significantly
just remember to shut the door or disable the interior lights so they aren't on.
- reconnect the battery cable
- pull one fuse at a time
- place one lead of the meter on one terminal of the fuse socket
- place the other lead of the meter to the other terminal of the fuse socket
- observe and record the reading
This will direct you to which circuit has a problem.
FarmMom68
May 9, 2019 5:23 PM
vendo
May 18, 2015 8:26 AM
plokm24
Feb 23, 2012 7:30 PM
rwrows
Apr 6, 2008 12:04 PM
hardwarz
Oct 17, 2007 7:14 PM
