Cooling fan Relays on Venture van
Old Aug 10, 2006 | 9:54 AM
ottawaventure's Avatar
Default Cooling fan Relays on Venture van
Hi guys
I have a problem with my 97 Venture cooling fans, like they don't work! I pulled out the relays in the engine compartment to test them then found out that they can be replaced in any direction??????? Do you know if the orientation of these relays are important? and if so what is the proper orientation!
Thanks in advance.
Old Aug 10, 2006 | 2:02 PM
NCHEVYHEVN's Avatar
Default RE: Cooling fan Relays on Venture van
Yea they can be put in any way.
Old Aug 13, 2006 | 12:26 AM
kcb37's Avatar
You may want to check that because, when the temp goes up, power should go to oneside of the relay and thur, this will activate a switch in the relay, once activated it will supply power to your fan. It is like haveing a light switch for a domelight, and a second electronicly controlled switch that will control the door lights when the dome light is turned on.
I hope that made sense.
echocluster
Mar 4, 2013 1:37 PM
jrhody
Aug 30, 2012 7:52 AM
ottawaventure
Aug 10, 2006 9:56 AM
