Couple Problems
Old Apr 27, 2009 | 9:12 PM
Pmount0's Avatar
Default deleted
delete
Old Apr 27, 2009 | 9:33 PM
cdc9266's Avatar
Default Questions
Do you drive on rocky roads (could be some of that noise is a rock stuck in somewhere) Are you burning any extra oil? Are your brakes up to par?
I had an early 90s lumina and had to replace was either the camshaft or crankshaft sensor (it was some time ago) It was above the oil pan. In any case the sensors can sometimes cause wierd issues like hesitation during acceleration had a bonneville that did something similar and again it was replacing the sensor that helped out.
Old Apr 27, 2009 | 9:53 PM
cdc9266's Avatar
Default Fuel Questions
Well my edit got lost in cyberspace but you already answered the questions about sensors.
What about your fuel preasure? Have you ever replaced the fuel filter?
Old Apr 27, 2009 | 10:08 PM
cdc9266's Avatar
Default fuel filter
If I remember there should be a filter on the fuel line along the frame line I am not possitive because some cars have taken to putting the filter in the tank with the fuel pump. Also if you you only replaced two injectors maybe the other old ones are having a problem keeping pace with the new ones.
Rray_85
Sep 5, 2022 12:14 PM
Snuggyworm
Sep 19, 2016 12:07 PM
Mudd Mutt
Feb 27, 2013 11:38 AM
ottof
Jan 8, 2008 10:39 PM
Mjd
Mar 9, 2007 1:24 AM
