Crossed wires
Old Jul 15, 2017 | 8:46 PM
Glen Shaffer's Avatar
Default Crossed wires
While replacing front brake calipers I noticed the speed sensor wires were disconnected. I spliced them together (Possibly, accidentally backwards) now it won't start. It won't even turn over now i don't know where the wires run or if anything shorted out. Is it more likely that I messed something up or the starter or a sensor went bad?
Old Jul 15, 2017 | 8:53 PM
kevinkpk's Avatar
It cranks, but won't start, or does it not crank (turn over)?
Old Jul 15, 2017 | 8:54 PM
kevinkpk's Avatar
If it's on the speed sensor, you should have an abs code.
Old Jul 16, 2017 | 12:50 AM
Disconnect the sensor and check for a blown fuse.
Old Jul 16, 2017 | 6:20 AM
There is no crank, and no the clicking of the starter.
Is throwing a camshaft position sensor code, but I haven't had any problems before this
Old Jul 16, 2017 | 7:23 AM
kevinkpk's Avatar
Reverse what you did with the wiring, see what that does. It could be a coincidence.
Old Jul 16, 2017 | 9:33 AM
So now it's throwing 3 codes
1 is the engine speed sensor
2 is crankshaft position sensor A
3 is camshaft position sensor a bank 1
