Dash gauges problems
Hi, I have a 2002 Cadillac Escalade recently it dash gauges started acting up they will be in normal operating position then all of a sudden they just drop all they way down for a few seconds then back to normal I noticed my volt gauge is moving back and forth as well I had the alternator and battery tested and both checked out any idea what could cause this, thanks in advance
In that time frame, GM had problems with the stepper motors for the gauges. They are not expensive and if you can solder, it is fairly easy to do. If you are doing it, replace all 6 while you are in there to avoid having to do the job again at a later date for a different gauge.
mma2012
March 1st, 2017 11:13 PM
silveradontn
June 15th, 2013 10:11 AM
andrec031179
August 1st, 2006 4:08 AM
