Desperate 5.3ls help
Old Jun 18, 2021 | 8:39 PM
Thomas Neels's Avatar
Default Desperate 5.3ls help
I bought a used 5.3ls motor. The other one blew up no oil pressure. I put a new oil pan without the relief valve in it, New pick up tube with o ring, new high volume oil pump, 5w30 oil. primed the new pump put a mechanical Guage so I could check the oil pressure at the port for the oil pressure sensor which i put a new screen in there as well. Still no oil pressure until I fired it up and reverse it up to 3000rpm then got 20psi but when let off the gas it drops to 0. I have been dealing with this issue for 4 months and we desperately need our tahoe back. Any suggestions would be appreciated. Thought about draining the oil for the 7th time and maybe putting in a thicker oil. I just need to figure out how to get oil pressure to the top of the motor. Also if I take my mechanical Guage off and turn it over oil does shoot out the top but I dint know why I can't get oil pressure it's got me stumped PLEASE HELP I have alot of money invested in this to blow it up again.
Old Jun 19, 2021 | 10:57 AM
kevinkpk's Avatar
I could be something like drain back valve in the oil filter, might throw 10 bucks at it first.
Old Jun 19, 2021 | 11:05 AM
we bought the new oil pan without the relief valve in it are you suggesting just a new oil filter
Old Jun 19, 2021 | 1:11 PM
kevinkpk's Avatar
Yes. I am
Old Jun 19, 2021 | 1:15 PM
Rednucleus's Avatar
Got any history on this used motor? How many miles; compresison test?
My high miles (350k) 5.7 cannot hold hot idle pressure over 5psi on 5/30; on 20/50 no problems 15psi
Thomas Neels
May 23, 2024 7:54 PM
Thomas Neels
Jun 18, 2021 8:40 PM
Thomas Neels
Jun 18, 2021 6:50 PM
rog777
Jul 13, 2009 11:24 AM
btechbish
May 9, 2008 7:28 AM
