Disconnecting ABS module help?
Old Nov 3, 2012 | 11:37 PM
deepstuff's Avatar
Question Disconnecting ABS module help?
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]-->Hi,
I want to disconnect the harness from the ABS module to test the harness. There appears to be locks in place to lock the harness in place on the ABS module? How does this disconnect?
Thanks
Uploaded with [URL=http://imageshack.us]ImageShack.us[/URL
<!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]-->
badgunz
Jan 24, 2016 5:26 PM
KDaniel
Nov 26, 2013 4:35 PM
deepstuff
Nov 4, 2012 8:00 AM
averslawn
Mar 9, 2011 9:20 AM
Throttle
Jan 4, 2008 2:26 PM
