Door Issue
Old Feb 22, 2018 | 5:08 AM
tennesseez's Avatar
Default Door Issue
Good Morning
I have a 2005 Chevy Silverado 1500 Crew Cab ( 4DR) Z71 4WD Pick Up, The Passenger side rear Door will open from the Outside of truck using Handle , But when you pull the Handle from INSIDE the truck, Handle Moves but doesnt release the Door to open. Is this a Common problem? Thanks
Old Feb 22, 2018 | 7:44 AM
It happens occasionally with everything being made out of plastic now. You will need to remove the door panel and see what is disconnected. If you are lucky it will be an easy fix. My 2013 did the same thing and I had to buy a repair kit for about $75 to repair it. A plastic tab broke because someone jerked the handle too hard.
