Door Lock Issues
Old May 2, 2013 | 7:13 PM
dcoperator's Avatar
Default Door Lock Issues
Ive got a 2009 Avalanche with intermittent door lock response on drivers side rear door. Regardless of whether I use the fob or the drivers door lock button, the rear door sometimes does not lock when activating the control. Any help would be appreciated! Thanks...
Old May 2, 2013 | 8:07 PM
Brok's Avatar
Sounds like you have a bad electrical wire running to that side. Either you have an open or shorting somewhere. I would pull the door panel and check the wiring. If it looks ok. You could have a bad input leading into the door lock.
nechevy
Dec 21, 2020 5:50 PM
refinisher
Jun 12, 2020 12:51 PM
Mastiff
Jul 12, 2010 8:39 PM
davbell22602
Mar 10, 2010 8:36 PM
joeysworld
Sep 15, 2008 11:21 PM
