The dreaded reduced power light
Old Jul 7, 2016 | 11:50 AM
outdoorguy1979@yahoo.com's Avatar
Default The dreaded reduced power light
Ok so I've read countless posts about this but let me tell you what I have. I have a 2003 chevy tahoe with a 4.8 v8. So my reduced power light came on so I had the codes read. It says I have a bad throttle body so I replaced it. Still not fixed so I replaced the throttle body pig tail still no fix. Any other ideas I have to go out of town soon
Old Jul 8, 2016 | 8:26 AM
cleveland63b's Avatar
what were the codes? there are no codes that say the throttle body is bad or any other part in most cases. Where did you get your replacement part?
Old Jul 8, 2016 | 1:35 PM
I forget the codes but there were a lot some were brake sensor codes the other that a code for the actulator. I ordered the part from a gm supplier
Old Jul 8, 2016 | 1:57 PM
I forget the codes but there were a lot some were brake sensor codes the other that a code for the actulator. I ordered the part from a gm supplier the code is a p1516 Tac module throttle actuator performance is what just now came up
Old Jul 10, 2016 | 3:22 PM
Update I put a big thick ground strap on the engine to the frame still doing the same
