Drivers rear turn signal/brake light not working
Old Jun 9, 2022 | 10:30 AM
Southfl's Avatar
Default Drivers rear turn signal/brake light not working
I have a 2015 Silverado and recently had a left rear turn indicator alert when using the turn signal. Saw the top bulb was not working and replaced the bulbs. After replacing the brake light and turn signal no longer work. I put the old bulbs back in and still nothing. Running tail light works at night, but no brake light, turn signal, or hazard.
any help would be greatly appreciated.
someone suggested it could be a loose ground. If that’s the case, where are areas To look for the grounds.
thank you
Yogi
Dec 12, 2021 6:25 PM
jeremie tessier
Jul 17, 2019 11:11 PM
david_alig
Aug 31, 2017 3:37 PM
ricky
Feb 4, 2011 6:50 PM
originalmazdawg
Mar 19, 2009 9:21 AM
