Eats power window motors
Old Oct 20, 2012 | 6:13 PM
spidey56's Avatar
Question Eats power window motors
Front passenger door eats power window motors. I am about to install fifth regulator in front passenger door. I will take responsibility for one as I bought the cheapest thing I could find. Original one lasted until June 2007. Second (Cheap) one lasted until March 2008. The rest have been GM parts. Third until September 2011; and fourth until October 2012. The failure mode has always been the same. The window works fine for a while, then becomes intermittent for two weeks to a month and then fails completely. Testing has always shown that both the master and door switches function correctly. With motor plugged in, there is +12 volt for one direction and -12 volt for the other direction from both switches. By comparison I have replaced driver side once July 2010.
Is my luck with passenger side really that bad or is there something I am over looking?
-Chevrolet
-2004 Suburban
-2WD
-5.3
-LT
-Loaded w/o Autoride or Sunroof.
Old Oct 20, 2012 | 6:28 PM
kevinkpk's Avatar
I'd call switch. Apply power to the suspect motor with it out, if it works, then switch.
Old Oct 21, 2012 | 9:08 AM
Is there any kind of bind that would put extra stress on the motor to make it fail?
Old Oct 22, 2012 | 6:18 PM
spidey56's Avatar
kevinpk - tested plug w/ motor unplugged to check switches (master and door) then with motor connected to circuit and voltage was good in both cases.
oldchevy - maybe original regulator began to bind before it failed but the two recent ones became intermittent but showed not signs of binding and then failed. The cheap one maybe bound a little its whole 9 month life.
To both - I guess I was not clear that each time it was replaced both regulator and motor were replaced.
brian74montecarlo
Apr 14, 2014 6:01 PM
dragracemaniac
May 16, 2012 8:17 AM
JoeBlow
Nov 25, 2011 5:14 PM
