electrical problems - won't turn
Old Apr 19, 2007 | 3:15 PM
nikde's Avatar
Default electrical problems - won't turn
hi, all:
i have a 61 biscayne and the other day, at the gas station, i lost all electrical (nothing happened when I'd crank). I assumed it was the switch and replaced it at the station, and everything was fine. Last night, I turned it to start and it cranked right up, then I pulled the lights, and the whole thing shut down (there's nothing, no spark, no electricity, no acc, etc). It's a fairly simple electrical system (the ignition has four prongs on it: acc, starter, battery, ign), and I can't figure out where the problem is. I don't have a voltimeter, and frankly, I'm broke (end of the month), so I'm not going to pop for one. Does anyone have any suggestions on where to start, where to look? All fuses look right.
Thanks,
n
Old Apr 19, 2007 | 6:52 PM
hillbilleous's Avatar
Default RE: electrical problems - won't turn
check your battery connections on either end (both grounds and both positive on batt. and starter)
ZChevyAK
Nov 13, 2015 6:45 PM
yeshua
Dec 8, 2013 2:24 AM
G T Igofast
Sep 3, 2013 3:46 PM
mikeyi
Mar 28, 2009 7:53 AM
DERROLD
Aug 17, 2007 3:50 AM
