Emission tricks
Old Dec 2, 2008 | 8:06 AM
metal249's Avatar
Default Emission tricks
Trying to get my 77' Chevy pickup(250 ci.) through emissions. The motor has 300,000+ miles on it, so I don't want to make any significant repairs to a motor that wont last, but I am failing emissions. The first emissions trip, it blew 719 in hydrocarbons after the precondition, with the standard being 250. At the same time, my carbon monoxide was only 0.02 with the standard being 2.00. Since the truck sat for 4 months, I drove it 120 miles down the freeway to clean it out. I also tried to lean the carb, but it has only one adjustment screw. I turned the one screw in about a half turn. Back to emissions. Now my hydrocarbons are 632 and my carbon monoxide are 0.01. It seems strange that my carbon monoxide is so low while my hydrocarbons are so high. My temporary tag expires after tomorrow, and I cant get anymore so I need to pass tomorrow. I still need to go over the entire ignition system, but are there any tricks I could also try? I have two more shots at emissions, so I figured i would try the ignition system, new airfilter, and an oil change. If that doesn't work, I'm going to try denatured alcohol at about 25% and 75% 91 octane. Anyone have any expiriance with forceing a vehicle past emisions?
Old Dec 2, 2008 | 9:37 AM
northey87's Avatar
Default RE: Emission tricks
Are you sure it has to be smogged? The national cut off was '72 and older, butthat number has gone up in recent years but I don't know whaat the new cut off year is.
Old Dec 2, 2008 | 11:14 AM
cams 98 silverado's Avatar
i thought the cut off was 95 because of obd2 coming out. my buddy has a lifted 460bbf bronco and no emissions because its 1979. plus i wanna get my 1995 k1500 so i can make it a sleeper. but yeah
Old Dec 2, 2008 | 12:10 PM
metal249's Avatar
Nope, in AZ, it requires emissions. Anyone know where to find my firing order and timing?
Old Dec 2, 2008 | 1:32 PM
northey87's Avatar
Should be on the intake manifold somewhere.
I see what you mean. Its 1966 and older in AZ. http://www.azdeq.gov/environ/air/vei/tested.html
Old Dec 4, 2008 | 5:04 PM
jkgray80's Avatar
Your CO is low & HC's high b/c your ignition system sucks. You are over-fueling &NOT burning it. If you had high CO & low HC you would be overfueling & burning it. You need to check your basic items- plugs, wires, timing, etc, etc.
adamant
Jan 30, 2009 9:11 PM
Top
Follow Us
