Engine
Old Jul 17, 2009 | 1:40 PM
rwall's Avatar
Default Engine
97 Chev Caviler. 2.4 liter engine. How much is the maximum oil consumption? The CV air/oil separator seems to be working, however the oil filler cap when off seems to have excessive pressure build up. No blue smoke from exhaust ect.
Old Jul 23, 2009 | 1:37 PM
therewolf's Avatar
Under optimal conditions, none.
Assuming no oil is leaking out, how much is it burning?
Old Jul 27, 2009 | 3:27 PM
rwall's Avatar
Default 97 Cavy
It goes thru 3 liters in about a month 1000-1500 kms
Old Jul 29, 2009 | 10:10 AM
therewolf's Avatar
There's either something wrong with the PCV, or you're burning a LOT of oil.
Usually with a crankcase ventilation problem, you blow out your valve cover gasket and leak oil like a pig. So assuming everything is properly connected,(?) you're just burning a lot of oil.
What's the mileage on this engine?
jrsavoie
Dec 6, 2010 10:24 AM
luvmlkwag
HHR
Jun 5, 2010 11:05 AM
93chevyman
Mar 12, 2010 1:13 PM
larry_chip
Apr 24, 2007 11:46 AM
