Notices
Engine hot a/c off 2007 equinox
Old February 14th, 2011, 3:57 PM
CHESIMUS's Avatar
Default Engine hot a/c off 2007 equinox
This vehicle was started by remote and left to idle, after driving check engine light on with warning hot engine a/c off. No other history of problems help please
Old February 16th, 2011, 8:56 PM
RacerX's Avatar
does the remote start turn the fan on? if the fan doesnt turn on because your remote start bypassing the power line on the ignition circuit it could overheat if you let it idle for a long time.
Old February 17th, 2011, 7:40 AM
CHESIMUS's Avatar
The fans both were running all the time. I decided to have the thermostate replaced , as i also noticed lower than normal heat from the ducts. After the thermostate was replaced the check engine light was reset, the engine hot a/c off was reset and all appears to have been corrected.thanks to all previous threads that allowed me to help decide to make this repair.
tbarkermn
June 17th, 2016 9:25 AM
philhill61
April 21st, 2014 11:06 AM
hatchet
November 27th, 2011 8:21 PM
chevydevildog1890
June 5th, 2010 1:39 PM
Quick Reply: Engine hot a/c off 2007 equinox
