Engine Idle Help
Old Jan 28, 2023 | 5:14 PM
sendhelp's Avatar
Default Engine Idle Help
Hi all, I have a Chevy 383 in a 81 Camaro that has a edelbrock 1406 carb on it with hooker headers, mech fuel pump, borg Warner t-10, that has a very peculiar problem. It idles fine, and revs in neutral fine, but as soon as I drive it down the block it refuses to idle and stalls out in between gear changes. I have checked the idle/mixture screws, they are not moving, I also checked the fuel pump and it seems to be in working order. I also sprayed around with carb cleaner for a vacuum leak and haven’t found anything. Also the vacuum gauge reads 15.5
, so a little low. Please help with any suggestions. Thanks, George
clintsy
Aug 18, 2012 7:29 PM
SBchev350CGC
Camaro
Aug 18, 2012 1:29 AM
86silver
Mar 9, 2012 5:57 PM
projbelair
Jun 19, 2009 5:55 PM
