Engine smoking.
Old Aug 26, 2010 | 10:16 PM
hullb86's Avatar
Post Engine smoking.
I have an 88 Chevy C1500 with a 5.7liter v8 2wheel drive. The motor is a aftermarket GM crate motor. When I have the engine running in Idle or if I am in stopped traffic it smoke's like a freight train. I have checked the compression and all cylinder's are at about 150psi. Was wandering if my valve seal's could cause that? I also have a clatter in the top end under load and don't know if I can adjust the rocker's or if they have to be torqued down to spec.My main concern is the smoking though.
Old Aug 27, 2010 | 11:34 PM
2wd-K5's Avatar
might be the seals, what color is the smoke?
Old Aug 28, 2010 | 4:56 PM
hullb86's Avatar
Post smoke
The smoke is a blue color, pretty sure it's the oil. Just wasn't sure if the seal's could get that bad, trying to change them now having trouble getting the keeper's out. I have them where they get loose and spread but can't get a hold of them to pull them out.
Old Aug 28, 2010 | 5:39 PM
2wd-K5's Avatar
angled needle nose pliers works for me (sideways bend) get the cly u r working on to tdc on the valves you are working on
blackedout
Nov 24, 2013 3:07 PM
jacob brooks
Feb 3, 2010 2:30 AM
SuperTexan
Jun 13, 2009 12:41 AM
kobiewhite
Feb 23, 2009 2:26 AM
sage0501
Mar 29, 2008 12:38 PM
