Engine valve rattle?
Old Oct 20, 2018 | 8:13 AM
Firemanjoek's Avatar
Default Engine valve rattle?
2007 suburban Ltz, 190 k no major components replaced , I have a slight rattle when engine is at light to medium load( so going up hill in fourth gear with light foot peddle), if I accelerate slightly to down shift gear the rattle goes away, if I let off the peddle it goes away, it doesn’t rattle at idle or idle in gear, if I increase rpm’s in Park it doesn’t rattle, I think it is a valve lifter but just looking at suggestions, if it is a valve lifter I don’t think there is an adjustment or a easy fix, thanks for any info!!
Old Oct 21, 2018 | 7:14 AM
I have s buddy that suggested spark noise, all the symptoms run in line with that , hopefully it’s this easy but we will see
Old Oct 21, 2018 | 10:46 AM
geo1's Avatar
That noise at idle, maybe,what about a oil filter change,reduce some resistance?
Old Oct 28, 2018 | 1:19 PM
I replaced plugs and wires today(10-28), we will see if it solves my my symptoms, thanks
