Engine will not turn past certain point
Old Nov 20, 2014 | 5:20 PM
Filthybill's Avatar
Default Engine will not turn past certain point
I just bought a boat with a 1996 Crusader 5.7 GM 350. It has been sitting for 3 years. I took off starter and it had broken teeth. I replaced starter and it became jammed. After taking it off, I tried to turn engine over by prying flywheel with a screwdriver. It will turn in reverse, and when I try ccw again, it will turn to the same point, then get jammed. I don't want to force it and cause any damage if some has not already been done. Plugs are out, valve covers off, manifolds off. Where should I go from here?
Old Dec 2, 2014 | 6:49 PM
Badshot's Avatar
Is the engine still connected to the outdrive?
Old Dec 3, 2014 | 5:17 AM
Filthybill's Avatar
Pulled engine out. Will strip down in next couple of days. Afraid it's a connecting rod.
bebop123
Sep 9, 2013 3:14 PM
G T Igofast
Sep 3, 2013 3:46 PM
Nodakchevyguy88
Oct 9, 2011 10:12 AM
legolas894
Sep 9, 2010 9:02 PM
B-Rad
Mar 20, 2010 5:48 PM
