Engine wont Start ?? STARTER??
Old Jul 2, 2007 | 8:52 AM
paradice01's Avatar
Default Engine wont Start ?? STARTER??
Hey guys, Im having trouble with my 1999 Chevy Tahoe. Its got a 5.7L Vortec engine in it. So basically, the trucks been sitting for about a year and a half. Been workin on it a bit recently, getting ready to start it yesterday.
It wont start, when you turn the key to crank, you hear a click as if a faulty starter or solenoid. So we took the starter out of the truck, hooked it up to a battery, bypassing the solenoid, and it works perfectly fine. No weird noices or stickly solenoid.
We go & put it back in the truck, same issue again. So we tried to bypass it while it was on the truck, and it will struggle to turn the engine over as if the battery was dead, it would only turn the eninge like for 1 second, and then pop one of my ignition fuses.
Anybody got any clue whats the matter with my truck? Is the starter bad? Or do you think its a wiring issue, mind you since its been sitting, nothing has been touched on the truck, and as for voltage, its a brand new battery we put in it last week.
Old Jul 3, 2007 | 3:17 AM
Chev007's Avatar
Default RE: Engine wont Start ?? STARTER??
hi! have you done some tune-ups lately? anyways, there are several possible causes why engine won't start: Module problems as well as pickup problems are often caused by loose, broken or corroded wiring terminals and connectors. it could be that your starter is bad.. better check it.. also try to clear all connection.. it happened to my cousin's car before - upon checking all his gmc sierra parts it turned out that he has some poor grounding and loose connection somewhere.. cleaning it out fixed his prob.. so good luck..
pantera8250
Mar 11, 2010 1:04 PM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
paradice01
Jul 5, 2007 5:11 PM
paradice01
Jul 2, 2007 10:35 AM
