Enhance the Aesthetics of your 6th Gen. Camaro With VIS Racing Hoods
General TechGood at troubleshooting? Have a non-specific issue? Discuss general tech topics here. IF YOUR QUESTION IS SPECIFIC TO A CERTAIN MODEL, IT DOES NOT GO IN THIS SECTION.
Hey Chevy Camaro Owners!
We’re inviting you to explore top carbon-fiber custom hood options by VIS Racing crafted to elevate the exterior of your muscle car.
We’ll start our dive into the world of VIS Racing products with AMS Style Carbon Fiber Hood. It is a solid, heavy-duty construction fitted with fully functional vents to effectively dissipate engine heat and maximize the performance. AMS Style Hood boasts an edgy design adding a head-turning touch to the front-end appearance of your Camaro.
The most aggressively-looking upgrade for your high-performance daily driver is the Terminator Style Carbon Fiber Hood. This hood boasts an angular design and vents to keep your engine cooler.
The underside of VIS hoods is reinforced fiberglass with a one-piece fiberglass covering. They feature a lightweight two-part construction to improve your Camaro’s power-to-weight ratio. VIS Racing products are made from 100% ISO-certified, grade-A carbon fiber material. Please note that professional installation is recommended, and in some cases, modification of the factory hinges is required.
Not ready to alter the clean stock appearance of your Camaro, yet need a high-quality replacement for your damaged hood? No worries, VIS Racing has you covered.
