Error code P0495
Old Feb 1, 2006 | 4:03 PM
tshunt01's Avatar
Default Error code P0495
I have a 2002 trailblazer LS. The check engine light is on. Checked the cooling fan relay sensors and changed them out. It's still making the high idle noise. Any ideas?
Old Feb 16, 2007 | 10:34 PM
John86's Avatar
Default RE: Error code P0495
it's prolly ur fan clutch they r bad about going out.
Old Feb 16, 2007 | 11:44 PM
golfer's Avatar
ORIGINAL: tshunt01
You'll have to describe what P0495 is ??
Old Feb 19, 2007 | 12:26 AM
John86's Avatar
DTC P0495
Circuit Description
The cooling fan relay sends a pulse width modulation (PWM) signal (12-14volts) to the cooling fan by the cooling fan clutch supply voltage circuit. The powertrain control module (PCM) uses the PWM signal, which controls the speed of the cooling fan by controlling the position of the oil control valve inside the clutch. If the cooling fan RPM is to high when the PCM is commanding 0%, DTC P0495 will set.
according to the flow chart if u already replaced the relay next to replace is ur fan clutch.
edteach
Sonic (Aveo)
Jan 18, 2008 4:33 PM
dj59red
Oct 9, 2007 4:39 PM
dj59red
Oct 9, 2007 3:25 PM
Mother_Trucker
Sep 10, 2006 12:01 AM
