flywheel thickness specs
Old Apr 9, 2013 | 12:54 PM
onegalonly's Avatar
Default flywheel thickness specs
hi all, new to the forum.. need to know if i can turn down my flywheel 1/8".. the flywheel looks like it is 1 3/16" thick.. the problem is that i am using a ram hydraulic throwout bearing and i need to shim the bellhousing to engine 3/8" to get the proper setup gap for the throwout bearing to pressure plate fingers.. i ordered a 1/4" spacer (bellhousing to block) from summit but still need 1/8".. turning down the flywheel by 1/8" will put me where i need to be.
Old Apr 9, 2013 | 1:04 PM
kevinkpk's Avatar
The only thing I see is loosing that 1/8" area on the teeth for the starter. Can't you just adjust it out?
Old Apr 9, 2013 | 1:29 PM
onegalonly's Avatar
the mating surface to disc is what i want to cut down.. that wouldn't have anything to do with the teeth.. the RAM hydraulic bearing is only adjustable with shims if the gap between bearing and fingers is too great
Old Apr 9, 2013 | 2:08 PM
kevinkpk's Avatar
I ujnderstand, but you are still moving the teeth 1/8 inch away. Otherwise I see no issue with it. If this is an issue, take the bellhousing at the starter input shim 1/8. That would also require altering the mounting holes. Give it a shot. That 1/8 might not be critical.
Old Apr 13, 2013 | 9:27 PM
onegalonly's Avatar
just an update.. turned flywheel down 3/32 and resurfaced .003.. added 1/4" spacer between engine and bellhousing and whalah, the perfect gap..
Oulderfauder
Sep 5, 2013 3:38 PM
motorman
Mar 29, 2013 10:47 PM
retsub
Jan 21, 2012 8:56 AM
buckdawg
Feb 7, 2009 10:30 PM
mrl
Aug 31, 2006 12:23 PM
