FRONT GRILL REMOVAL
Old Mar 21, 2008 | 12:37 PM
AKFINEST's Avatar
Default FRONT GRILL REMOVAL
I am trying to find step-by-step and photos to guide me to remove the stock front grill on a 2007 Chevrolet Express 3500 Van. This is a conversion van and would like to remove it to assist in the install of a T-Rex Aluminum Grill. The space to work without removing the grill to install the T-Rex Aluminum grill is minimal. I found the two top bolts (10mm) on to and two clips on top but after that, I am unsure what to pull or push to remove the stock grill. Thanks.
[IMG]local://upfiles/16697/28CA597FBE804466A3D8836C29DF96F4.jpg[/IMG]
[IMG]local://upfiles/16697/B68979AB345A4C1FBE77FA10A66DD708.jpg[/IMG]
Old Mar 22, 2008 | 8:24 PM
jkgray80's Avatar
Default RE: FRONT GRILL REMOVAL
Most simplegrille you will ever remove. What you are missingis 2 10mm bolts! Pop out your turn signal lenses. There is a release you can push w/a flathead screw driver for each one ( At the outmost side viewed from the side) Then you just have clips. Pull grill. Pull outany metal clips that stay on vehicle & reinstall on grille.
xD
Sep 6, 2010 9:08 AM
CRFrizzell
Oct 29, 2008 7:18 PM
Classical Glass
Jun 10, 2007 1:43 PM
Gmann
Mar 11, 2007 5:39 PM
