front passenger turn signal issue
Hello, I am new to this forum so hopefully i am in the right place.
I am having a major issue with my front passenger turn signal on my 2011 silverado 4.8l v8 1500. Everything works on all othertail lights and driver side signal. the front passenger running lights do work but that is all. It is the same bulb but i do not have power to the plug. All fuses have been checked and are fine. basically what happened is when I installed my 3157 led switchbacks for turn signals I had a hyperflash issue. I went to install load resistors to fix the problem and it did work but when the signal light came on it was signalling quit dim compared to the brightness of when it was still hyperflashing. i figured maybe bad connection or wrong wire. So that being said i touch two wrong wires on accident and lost all power from my turn signal and hazard light and those two bulbs only. Like i said running lights still work. bulbs are good still as they work in other sockets. Desperate need of help here and i appreciate any feedback. I am hoping there is something that is an easy fix i am not aware about.
Thanks in advance,
Michael.
Thanks in advance,
Michael.
