fuel injection
Old Feb 2, 2008 | 5:49 PM
2fubar's Avatar
Default fuel injection
I have a 97 chev crew cab dually with the 454 and I ran it out of gas. I put gas in it and it won't start. I turned the key on a few times to prime it but it still won't start. Anybody know what I'm doing wrong?
Old Feb 3, 2008 | 12:38 PM
dewey's Avatar
Default RE: fuel injection
Can you here the pump run, when you prime it? Can you check fuel pressure? Can you tell if there is air in the lines?
Old Feb 3, 2008 | 12:54 PM
2fubar's Avatar
i cant hear the pump working...might be my alarm though...it has an aftermarket alarm that disables the fuel pump..i dont have the book on the alarm so i cant tell which buttons or combination of buttons i need to press to reset...
Old Feb 4, 2008 | 12:08 PM
dewey's Avatar
You should be able to run the pump from the pump relay, just for testing. There may be a prime connector close to the relay.
If you know who manufactured the theft system, they may have a web site. They might be able to give you some information.
Old Feb 4, 2008 | 6:30 PM
shawnvw's Avatar
Banned
is it a diesel?....you will have to bleed the fuel system if it is.
ERV9584
Apr 29, 2007 11:07 PM
degree
Nov 29, 2006 7:35 PM
rich
Mar 28, 2006 6:55 PM
