Fuel pressure regulator location
Old Aug 13, 2020 | 5:11 PM
Yellowrocket's Avatar
Default Fuel pressure regulator location
I own a 2007 Silverado ( new body style). I am having issues with the fuel pressure regulator ( pressure bleeds slowly down and hard starts first start of the day). I believe my pressure regulator is going out. Problem is the regulator is not mounted on the fuel rail as I thought it would be. So I believe the only other location would be in the fuel tank?
any help appreciated.
2007
6.0
4 wheel drive
LTZ PACKAGE
Old Aug 14, 2020 | 7:06 AM
Welcome from Florida. Does your truck run good after it starts? If it does then your problem is not with the fuel pressure regulator. More than likely you have a bad check valve in the fuel pump assembly. You can either change the fuel pump or add a check valve in the fuel line.
Old Jun 19, 2021 | 11:38 PM
TheBeatnik's Avatar
Default Fuel Pressure Regulator in a 93 Caprice LS 5.0 V8 Engine
Hey everyone,
My car has to crank for 3-5 seconds before starting. This can be a cold start in the morning or after sitting for ten minutes. I had a diagnostic test performed and the starter failed the test. A mechanic however said it was not my starter but my fuel pressure regulator. After watching various youtube videos and reading my manual, I think the fuel pressure regulator is located underneath the throttle body. Does that sound right?
If anyone has a picture of where it is located that would be greatly appreciated too. I found what looks like a fuel pressure regulator but it is located near the top right of the firewall on the drivers' side.
Any ideas are greatly appreciated!
Thanks!
Cheyenne98
1988 - 1998 (GMT400)
Jun 19, 2018 1:27 PM
HUNTER97
Mar 23, 2013 3:46 PM
Basshoggin
Jun 20, 2011 8:46 AM
ehhget
Feb 18, 2008 1:57 PM
carlsndfw
Jan 8, 2007 5:10 PM
