Fuel Pump Issues 2000 Silver ado
Old Apr 19, 2012 | 12:27 PM
strightclaw's Avatar
Default Fuel Pump Issues 2000 Silver ado
OK this will take a bit. So here we go.
I got this truck when my Dad pass away. At the time the sending unit in the gas tank would work intermediately. I replaced the pump and sending unit because of this. About 6 months later the new pump quit working. I replaced the pump with another new one. It got to where it would act like the original, and the sending unit would work when it wanted to. I put up with that for a bit. Then the pump itself quit. About a week later after it quit I tried to crank it and it started up. The sending unit still not working correct. I have driven it about a year now, and the other day it quit again. After it had set about two hours it cranked up again. Its been just a few days now and it has quit again. I also noticed when it quit the gear selector light went out. Could this be a computer problem ? Strange that the light went out along with the pump.
Old Apr 20, 2012 | 5:33 PM
RacerX's Avatar
sOUNDS like a ground wire problem.
Old Apr 21, 2012 | 8:45 AM
Did you buy a cheap aftermarket pump? They usually don't last long.
Old Apr 21, 2012 | 4:44 PM
No Its a Carter Pump But I found the problem. Wire at the connecter shorted out.
The Lord is GOOD
Pdx_Repo
Sep 24, 2014 4:02 PM
rob in nh
May 5, 2012 11:09 AM
hunter10220
May 18, 2011 8:37 PM
juddkennedy
May 22, 2010 4:28 PM
JackTheTripper
Mar 19, 2010 12:25 PM
