fuel pump problem
Old Oct 5, 2006 | 3:35 AM
jason07's Avatar
Default fuel pump problem
Hello,
I have a 2001 Chevy Tahoo with 120,000miles and the fuel pump is not working. I am not getting constant pressure and at times no pressure. Before I replace the fuel pump I wanted to see if there is a sensor that would be causing this to happen?
Thanks.
Jason
Old Oct 10, 2006 | 12:28 PM
car56's Avatar
Default RE: fuel pump problem
hi, I also have a Dodge van that had a similar problem. it should be somewhat similar, there is a crnkshaft sensor and cam sensor common fed from computer. if the voltage is low they won't let the relay kick in for the fuel pump. check your fuel pump relay it should have 12 volts to the coil with the key on. if you hve low votage to your sensors check the capacitors in the computer(easy) and replace. fuel pump may be bad but it sounds like maybe what I said or a bad relay, either way it's easy to fix either even computer and will save you a ton of money. good luck!
Old Oct 11, 2006 | 11:03 PM
Chev007's Avatar
I also had irregular pressure and another thing is I got noisy fuel pumps. I tried bypassing the fuel pump relay but still the problem persists. Seems my fuel filter is also plugged. A failing pump is what I also suspect. Need to shed out a few bucks again [].
Old Oct 14, 2006 | 9:59 AM
sjenkinzz's Avatar
new fuel pump..big $$$$
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
