Fuel pump question....
Old Jun 30, 2009 | 10:13 PM
aartod's Avatar
Default Fuel pump question....
I have a fuel pump issue and I was wondering if anyone has had a problem like this before or knows anything about it. The car has a 86 4.3l tbi v6 and has a in-tank fuel pump. It wasent starting so when I was checking for fuel I disconnected the fuel line at the throttle body and cranked over the car and fuel spurted out for about a second or two then it stopped flowing alltogether... so I tried it again and the same thing happened over and over. So then i checked to see if there was power getting to the fuel pump all the time not just during the intial start-up--- and there was... I unplugged the connector by the tank and put a test light on it and there was constant power while cranking. So if there is power getting there and the pump is not pumping enough then I figure it needs to be replaced... But I have never see this before, I have seen them not work at all, or not enough pressure, but not a big spurt and then nothing- everytime! What do you think?
Old Jun 30, 2009 | 10:49 PM
EvansBlue's Avatar
I have actually seen that a couple of times.
I think its has to do with a hermetic seal inside the pump. I'll elaborate later... I'm mobile at the mo'.
Old Jun 30, 2009 | 10:57 PM
aartod's Avatar
yes, please elaborate I dont know what a hermetic seal is!
Old Sep 30, 2009 | 3:48 PM
dunhamr's Avatar
If it was me, I would just replace the fuel pump if it was a seal inside the pump going bad
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
