Fuel Regulator. And wire question
Old Apr 20, 2013 | 6:54 AM
sleepingciv's Avatar
Default Fuel Regulator. And wire question
I have a 99 Tahoe with a 5.7.
Is there anyway to test the regulator at all?
Also anyone have All Data? I need to know where 2 wires go from the PCM.
Plug C4 pins 11 and 13. I have the pinouts but it dont say where they go from there.
Thanks
Old Apr 20, 2013 | 8:54 AM
Camaro 69's Avatar
Site Ambassador
A simple test is to remove the vacuum hose at the pressure regulator. If there's gas in there, it's bad. Next would be to hook up a pressure gauge to the fuel rail and take a reading when the engine is running. Google your truck to see what the pressure should be. Generally, when a regulator goes bad, fuel pressure reads high.
Old Apr 20, 2013 | 9:15 AM
Thanks for the reply.
Can I get to this hose even thought the regulator in under the intake manifold?
I have a gauge it primes about 58 while cranking goes to 60, it starts then dies fuel pressure drops to 50.
Pump is new so is the filter.
Old Apr 20, 2013 | 3:51 PM
kevinkpk's Avatar
Sounds like regulator, and you have to remove the intake to get to it. The vaccum hose too it may not require removal of the intake, however you need to check for gas in the vacuum line close to the regulator.
Old Apr 21, 2013 | 3:48 AM
Thanks will see what I can find.
Old Apr 21, 2013 | 10:10 AM
Ok Im no seeing the vacuum line for the regulator lol. Anyone have a pic of it?
Old Apr 21, 2013 | 2:41 PM
kevinkpk's Avatar
Old Apr 22, 2013 | 7:04 AM
Ya I had seen that video. Isn't there a hose to ne attached to that nipple?
Old Apr 29, 2013 | 5:32 PM
Dusty1's Avatar
No there is no hose to the nipple of the regulator ! I just replaced mine rebuilt the spider injector replaced all gaskets filter and pump was a pain in the *** to find out pump was faulty all along
barnesam
Dec 31, 2022 2:34 PM
markwemple
Aug 5, 2014 12:23 AM
solerano
Sep 1, 2013 5:26 PM
David5292
Apr 25, 2012 8:31 PM
Simplejack
Feb 7, 2012 7:28 PM
