Fuel sender
Old Aug 11, 2013 | 6:10 PM
1991cheytruck's Avatar
Default Fuel sender
OK need a little help with this; so I am no longer running the computer in the truck anymore. I am trying to figure out the 3 wires on the fuel sender for the tank.
PPL wire - is the fuel gauge
BLK/W wire -
grey wire -
the other two wires go to the computer, trying to figure out if I have to use both of the wires or I can just use one to turn the fuel pump on. I know that I will have to connect a switch to the wire so I can turn the fuel pump on manually.
Any Ideas?
Old Aug 11, 2013 | 10:21 PM
a lot of gm products of that age use the grey wire for power to the f/p but I haven't verified that for your truck.
so how is the setup going to work? you have gone back to a carb and want to run an electric f/p?
Old Aug 11, 2013 | 10:51 PM
Default fuel pump wire
The only big thing I changed on the fuel line; put a fuel regulator and gauge to see how much fuel is flowing through the line. so I can control the fuel flow. I know that the pump pushes more fuel out then I want.
I think I will use a switch to turn on/off the fuel pump hoping that will work, the truck had the small 4.3 engine/w a manual and I drop in a 383 stroker motor and kept the same transmission.
ve6nu
Aug 30, 2014 11:33 AM
JohnG20
Oct 12, 2013 11:26 PM
bsr2002
Jun 4, 2011 8:19 AM
microsvc
Sep 19, 2009 9:45 AM
staubrj561
Nov 3, 2007 8:04 AM
