? ground wire gets red hot ?
Old Sep 27, 2007 | 4:17 PM
pete90's Avatar
Default ? ground wire gets red hot ?
wheni connect the batteryto the engine the ground gets red hot.ant ideas?
Old Sep 27, 2007 | 4:59 PM
John86's Avatar
Default RE: ? ground wire gets red hot ?
u have a direct short in ur cables. make sure positive cable isn't touching the frame or nething. check on the start to make sure it's not touching the bellhousing there.
Old Sep 27, 2007 | 10:31 PM
golfer's Avatar
Or the battery is being hooked up reversed.
Old Sep 29, 2007 | 4:48 AM
astroDZak's Avatar
Is this the small wire thats going to the body of the car getting hot? If so the big ground wire going to the engine block is not making connection and everything is trying to run off the small wire.
Old Oct 4, 2007 | 6:12 PM
roadkill's Avatar
main ground/small ground not in good contact. if they are, look for a hot ground. +cable or alt to batt wire may be grounding. smell any burning wires?
aapstealth
1988 - 1998 (GMT400)
13
May 2, 2025 12:00 PM
Joe Kehm
Oct 20, 2013 5:03 PM
MegaMiles
Apr 19, 2011 11:43 AM
hometheaterman
Jan 15, 2011 6:37 PM
