HAZARD LIGHT CONTROL
Old Oct 4, 2007 | 6:23 PM
roadkill's Avatar
Default HAZARD LIGHT CONTROL
anyone with a 1998 silverado having issues with the column mounted hazard light switch not working right? i have to bang on it a few times to keep them going. is this an easy fix if i need to replace?
Old Oct 4, 2007 | 7:09 PM
caprice_coupe's Avatar
Default RE: HAZARD LIGHT CONTROL
Sounds like a grounding issue. If you get it off test the switch and the wires at the switch too. Hate to put a new switch on and have bad wires. Far as easy fix, shouldn't be too hard just take your time so you don't tear anything up. Another work around would be to get fixed whatever is causing you to use your flashers all the time.
666threesixes666
Aug 18, 2012 7:18 PM
beckya99
Jul 12, 2011 12:29 PM
techchic
Feb 21, 2009 3:13 PM
fijidaniel
Feb 4, 2008 11:25 AM
karllap
Jan 19, 2008 4:22 AM
