Head Gasket???
Old May 23, 2010 | 1:33 PM
stumpbumper's Avatar
Default Head Gasket???
I have a GMC 4x4 with a 5.7. Steam is coming from the tail pipes...more so from the passenger side...also sounds like it is missing on the side. Listening to the engine bay it sounds normal, except for a hint of it missing. We pulled the plugs one at a time and fired it up, but no change and all wires were firing. The plugs were filed bad...like rounded and a significant gap. I decided to turn the engine over with a plug out on the driver side and water shot out like a shotgun blast.
The initial issue was discovered when it ran hot.
What could it be? my suspicion is the head gasket. With the motor not sounding or driving rough (short test drive) i assume the heads are okay. If I am correct how difficult is it to replace (by a knowledgeable family member and myself) or how costly by a mechanic.
Also, will the catalytic converter be ruined by the water?
Thanks for the help!
Old May 25, 2010 | 6:06 AM
duanesolson's Avatar
Sounds like a head gasket. It can be a time consuming task but not too bad. Attention to detail!!! I always have my heads inspected and tested by my local automotive machine shop. Money well spent.
Cat conv??? I have never had an issue but that doesn't mean that there wont be.
Old May 25, 2010 | 10:37 AM
gotstylez's Avatar
you could check your oil too.. see if is milky.
Old May 25, 2010 | 11:35 AM
Leaking head gaskets do not always leak water into the crankcase even though it normally does
Old May 27, 2010 | 3:45 PM
fastcarjoe's Avatar
Could be worse than just a head gasket. It could be a cracked head. A good machine shop can test the head for leaks when you remove it.
Old May 27, 2010 | 6:11 PM
cooter26's Avatar
It is your intake gaskets
Old Jun 4, 2010 | 7:36 AM
Terry Neff's Avatar
A blown head gasket/cracked head would pressurize the cooling system.Take off the rad cap and wait for the thermostat to open,then check for bubbles in the rad.
DOBERDEWD
Dec 11, 2011 11:35 PM
Dads Toy
Oct 21, 2011 6:54 AM
gulfcoastjoe
May 4, 2008 12:38 PM
malibu_iceland
Jan 6, 2008 12:03 PM
