HELP!! 2006 TB rough idle while in drive
Old Jul 24, 2018 | 9:05 PM
MistyH's Avatar
Default HELP!! 2006 TB rough idle while in drive
Place suv in neutral or park idle calms down. 173,000 miles on vehicle now. Already cleaned throttle body, new plugs, new fuel pump after sending unit went out. Checked belts, etc. Turn AC off rough idle calms down slightly but still there. Embarrassing since causes front bumper and all to rattle. Any noice on my car drives me crazy. Help me diag issue, pulled codes do have a few, o2 sensor bank 2 to lean or rich, evap small leak, evap running to rich or lean, or coolant thermostats not running at correct temp. Car never runs hotter then 210. Do need to replace A-frame bushings however will not impact idle just pull of car when brakes are applied. Ordered new ones. Don’t know what else to check. Have been told motor mounts however others have stated not even this has fixed idle problem. At 98$ a mount would like to be sure before this next step. Please help!!! Suggestions any of all kinds welcome!!
